Dizzy Fitting
7 replies to this topic
#1 Maccmike8
Maccmike8
  • 1,101 posts
Posted 18 June 2023 - 01:53 PM
Hi folk.
Getting round to fitting the 1275 engine in place of 998.
Engine came with no dizzy, have sourced one thanks to AC Dodd.
Please help.
No 1 cyl. Far right. Piston is at TDC, both valves are shut. I have the wok inspection cover off looking for a marking but cannot see one at all, not just in this position but full 360.
The dizzy key way is at 11 and 5 on a clock face.
On the 998, i took it off and looked, at TDC it was 2.30 and 8.30.
So the dizzy rotor arm is pointing in a different direction when comparing the 998 and 1275.
Any advice would be appreciated.
#2 KTS
KTS
  • 2,490 posts
Posted 18 June 2023 - 02:56 PM
re-position the distributor drive spindle to give the correct orientation
#3 Maccmike8
Maccmike8
  • 1,101 posts
Posted 18 June 2023 - 02:57 PM
Thank you KTS.
Just had a google and Ive now done exactly that.
There was a white mark on the flywheel, no 1 valves are shut and at tdc.
Removed the drive and now in at the correct place.
My first time for this lol.
#4 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 18 June 2023 - 11:53 PM
I’d suggest adding an external timing pointer and mark on the crank pulley so you can easily check the timing once it’s running
#5 Steam
Steam
  • 933 posts
  • Local Club: Victorian Mini Club
Posted 19 June 2023 - 06:02 AM
Why would the 998 position differ from the 1275 and from supplied dizzy or do we assume a previous owner bodge?
#6 Lplus
Lplus
  • 990 posts
Posted 19 June 2023 - 08:25 AM
We assume the previous owner of the 1275 had inserted the distributor drive in the wrong orientation.
#7 Maccmike8
Maccmike8
  • 1,101 posts
Posted 19 June 2023 - 04:55 PM
I assume its been removed and not put back correctly.
#8 Maccmike8
Maccmike8
  • 1,101 posts
Posted 19 June 2023 - 04:56 PM
Conveniently already has some, once running il adjust the the timing.
