Which would you recommend?
Posted 29 June 2023 - 09:46 AM
Posted 29 June 2023 - 10:01 AM
the top one stops at the suspension turret
the bottom one goes all the way back to the seat and looks a bit wider, i,e. right up to and past the edge of the battery tray
the other difference is the bit that meets up to the stiffener bracket, it looks like the black one is designed to have a new bracket fitted on top whereas I know the silvery one is designed to just fit over the top of the existing one. again depends what your plans are exactly
how much of the panel do you need to replace (pics might help)
from what I've seen usually it's just the bit behind the wheel well near the light cluster and around the subframe mount in which case both options work
neither of them are really 'ideal' in that they have an upwards return around the edges and they're designed to just sit on top of the existing parts, it all depends how much you're planning to cut out and replace, there's no one-size-fits-all answer obviously
bear in mind as well that corner is a bit complicated, with an extra layer beneath for strengthening, and i believe the valence has a closing panel which overlaps that point as well (3 layers total under the bracket ?)
Edited by stuart bowes, 29 June 2023 - 12:00 PM.
Posted 29 June 2023 - 10:36 AM
Posted 29 June 2023 - 10:48 AM
if you have a look at the link in my signature and go back to post #88 (page 6), from there onwards you can see what I did with the magnum panels (silvery ones)
I'm not keeping my external seam but that method should still work if you are
Edited by stuart bowes, 29 June 2023 - 10:48 AM.
Posted 29 June 2023 - 10:56 AM
Posted 29 June 2023 - 12:06 PM
Posted 29 June 2023 - 01:03 PM
Try the M-machine boot floor panels if you can, they don-t have the pressing & cut-out that goes over the boot floor to arch.
Posted 29 June 2023 - 01:10 PM
None of them. I tried MAGNUM ones and M-MACHINE ones, they don't fit., ended up replacing the boot floor.
Posted 29 June 2023 - 01:17 PM
In fairness that is what I probably should have done and that does make sense but having already bought them and the fact they're pretty much the right shape to start with does make things a bit easier I just modified them to do what I neededNeither of them go under the reinforcer.I would use card to make a template and cut out of sheet.Cut old rust away and replace the reinforcers underneath.Steve..
Edited by stuart bowes, 29 June 2023 - 01:19 PM.
Posted 29 June 2023 - 01:25 PM
Edited by stuart bowes, 29 June 2023 - 01:25 PM.
Posted 29 June 2023 - 02:16 PM
Posted 29 June 2023 - 05:09 PM
Posted 30 June 2023 - 07:17 PM
Edited by Steve-O 2014, 30 June 2023 - 07:17 PM.
