Rust Repair - What Panels ?
7 replies to this topic
#1 Badger360
Badger360
  • 29 posts
Posted 02 July 2023 - 05:05 PM
Hi all,
Have some rust coming through on the drivers side inner wheel arch - where the floor meets the inner arch.
Is there a repair panel for this ?
I am assuming it is the floor panel and toe board/ inner arch panel but not very clear to see which is which bit online
please see attached photos
#2 cal844
cal844
  • 9,663 posts
  • Local Club: TFMOC
Posted 02 July 2023 - 05:13 PM
You actually need the toe board and a front floor section. I'd personally double skin the toe board so you can run solid subframe mounts
#3 68+86auto
68+86auto
  • 1,030 posts
  • Local Club: Queensland Mini Car Club
Posted 03 July 2023 - 01:01 PM
Put in a new floor panel and then the other can be made easily.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 03 July 2023 - 01:40 PM
There's a little more going on there than just the flitch panel and what appears to be a so corrosion on a small part of the floor panel and toeboard.
There appears to be a patch on the sill as well so the question here is, what sill has it got fitted?? Oversill or standard short sill??
#5 sonscar
sonscar
  • 3,067 posts
Posted 03 July 2023 - 03:43 PM
What do you want?a repair or a possibly lengthy restoration.As Sonnik says there is more lurking.A sound repair is easily possible with hand formed sheet and the area is quite easy to access and repair.I am not suggesting a bodge.Steve..
#6 mbolt998
mbolt998
  • 408 posts
Posted 03 July 2023 - 05:08 PM
Cut out all the rust and then just buy some metal and work something out. It doesn't need to be perfectly shaped etc. because it's not an externally visible panel.
#7 Badger360
Badger360
  • 29 posts
Posted 03 July 2023 - 08:24 PM
I believe it has the short sills fitted the ones with open vent holes
Thanks for all the replies I think this winter I will tackle it as I want to remove all the foam insulation from behind the engine so might be a good time if the engine is out and I can flip the shell over
#8 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 04 July 2023 - 07:20 AM
So that’s relatively good news then so hopefully no nasties hiding there which we see oh so often on here.
I think the best thing you can do is fully wire brush every that appears to be affected and I mean using a twisted wire cup on a grinder.
Then you will get a better overall picture of what is actually affected. The problem with minis as I have reiterated countlessly over the year is minis rust from the inside out especially in any seams, so for example where the flitch wraps around the floor/ inner sill/ toe board.
