Hi all,
I'm looking for some advice on my Torque convertor...
quick backround on the situation before I begin.
Bought a JDM auto spi mini. Engine and auto box were knackered. Had a quick look myself and removed the torque convertor in the process (may have also removed all 6 bolts at once!!!). Decided autos are basically magic and sent the engine gearbox and convertor to a professional to get reconditioned and rebuilt. Got engine back fitted everthing back together. Didn't start.... Checked all the usual suspects, it's got fuel, spark, and TDC on number one dizzy rotor points at number one and number 4 valves are rocking. Stuck a timing light on it and its sparking at completely the wrong time... I then decided the problem might be the crank position sensor. But more specifically the ring its reading. I think it might be on in the wrong rotation.
So my questions are;
Can the crank position ring be in the wrong orientation?
Does it even come off?
