I've a strong coolant smell in the car (for the past 2 or 3 years) but never really bothered to check, the coolant level never moved so assume it was just the smell from the pipes somehow. I am using MS silicone ones fitted maybe 7 years ago.
I checked the coolant today and its dropped probably the whole air gap in the rad. Carpets dry, no oil in coolant, and oil looks fine.
Have filled the rad right up and will run parked to see where coolant might be leaking from. The overflow will certainly drain out until enough coolant is expelled to normal level so I'll have the max amount of coolant/pressure to spot any leaks.
Just surprised its taken this long for a significant coolant drop, but I am suspecting the car just got too hot, I had it out a few weeks back in the heatwave, had to use aux electric fan, and internal heater to cool it down! Its a 1293 retro twin injector s/c build. Runs perfect apart from coolant drop.
