Starter Motor Replacement
4 replies to this topic
#1 Ellesmere 62
Ellesmere 62
    Starting My Mini Up
  • 3 posts
Posted 05 July 2023 - 01:22 PM
Hi New on here so hopefully someone can help with my problem. Well here we go I Have just put a new engine in my 91 mini only to discover the 84 engine has an Inertia starter not a pre engaged so have now put in the correct one and a remote solenoid. my question is about the fitted starter Relay do I bypass it or can I just put a smaller spade on the brown and red wire and connect that to the new solinoid Graeme
#2 Ethel
  • 26,104 posts
Posted 05 July 2023 - 02:56 PM
Keep the relay and use it to switch the solenoid, that'd be my preference. You could keep later clutch though.
#3 Ellesmere 62
Ellesmere 62
    Starting My Mini Up
  • 3 posts
Posted 06 July 2023 - 09:20 PM
Ethel just wanted to thank you for your advice I have kept the starter relay have the car running now many thanks Graeme
#4 Ethel
  • 26,104 posts
Posted 06 July 2023 - 09:50 PM
Pleased your Min's up 'n running. It'll prolong the life your ignition switch & if the relay does die, you can just join the solenoid & ignition switch terminals on it together.
....little flash of perspiration, if they're not in a socket, you could use a piggyback terminal for the solenoid and make it even easier.
#5 68+86auto
68+86auto
  • 1,029 posts
  • Local Club: Queensland Mini Car Club
Posted 07 July 2023 - 02:42 AM
On a pre-engaged starter you need to use an external relay to activate the solenoid. The solenoid uses too much current, it might work for a while or for some of the time but it will not last long or be reliable.
