What Radiator Do I Have?
6 replies to this topic
#1 mrriggs
mrriggs
  • 11 posts
Posted 06 July 2023 - 11:31 PM
I'd like to buy a new radiator for my Mini but every one I see has the water inlet on the opposite side as mine.
Any idea what radiator this is? Are they available?
To swap over to a standard Mini radiator I'll need to replace the water neck and top bracket. There seems to be many variations of brackets. Which one would I need?
#2 Tds76
Tds76
  • 87 posts
Posted 06 July 2023 - 11:40 PM
Looks like it might be a late model Australian rad.
https://minisport.co...=44575235998006
Can you replace the thermostat housing & top bracket and go with the more common type?
Cheers, Paul
#3 Spider
  • 15,222 posts
Posted 07 July 2023 - 12:43 AM
That Radiator was fitted to cars that also had an Air Pump as part of the emissions system. Such engines popped up in Sweden, Switzerland, Canada and as Paul mentioned, Australia.
There are no replacements available that I am aware of, though, any decent radiator shop can re-core what you have (and I think you'd be best off going this way !).
If you do want to replace it, you can as Paul was thinking, go for the standard UK type, along with the thermostat housing and top radiator steady.
#4 mrriggs
mrriggs
  • 11 posts
Posted 07 July 2023 - 02:35 AM
Ah ha. This was likely a Canadian car so that would explain why it's different.
Unfortunately, environmental regulations have made radiator shops a thing of the past around here. There is one or two remaining but they deal with big commercial radiators and are too expensive for small jobs.
Converting over to a UK style radiator makes the most sense. I will get a new thermostat housing but am unsure what top bracket would fit. Any suggestions?
#5 68+86auto
68+86auto
  • 1,035 posts
  • Local Club: Queensland Mini Car Club
Posted 07 July 2023 - 04:28 AM
It looks like the same bracket would fit?
#6 Spider
  • 15,222 posts
Posted 07 July 2023 - 05:18 AM
This is the top bracket you'll need;-
Ah, sadly, it won't. The bosses on the standard thermostat housing are too low so the bracket needs to be able to reach around it ;D
#7 Steam
Steam
  • 846 posts
  • Local Club: Victorian Mini Club
Posted 07 July 2023 - 07:58 AM
I hve always found fabricating my own top bracket to be the best solution, that way I get the rad in the best position witout stress on ny components.
