Windscreen Rubber Orientation
Posted 17 July 2023 - 04:27 PM
Posted 17 July 2023 - 05:00 PM
Thin slot to body, wide slot for glass
Posted 17 July 2023 - 05:05 PM
Hi,
I fitted mine with the narrower slot onto the metal and wider slot onto the glass, which should be the norm. I would suggest however that you apply a sealant to both channels. 3m do one which does not set hard, sorry I cannot remember it's full name but it is black in colour. It can be a bit messy but it is well worth it as it does stop water getting in and down behind the dash and then onto the carpets.
Paddy
Posted 17 July 2023 - 06:54 PM
Hi,
Paddy
I agree, my fitter uses Arbormast on my cars.
Posted 19 July 2023 - 05:38 AM
Hi,
Paddy
What you are thinking of is 3M 8509 bedding and glazing compound. That is the correct product, there are also other manufacturers of equivalent products, search for a mastic windscreen sealant.
Posted 20 July 2023 - 01:23 PM
Position the rubber, with the join at the top of the screen, and the expander with the join at the bottom of the screen.
Posted 09 May 2025 - 12:29 PM
Am I wrong?
Posted 13 May 2025 - 01:02 PM
I tried my way with both joins at the top and also tried the rubber join at the bottom and expander/filler join at the top
With the rubber join and the expander join in the same place - the clip does not go in easily and also looks not seated correctly.
With the 2 joins sperate the filler clip fits better and must seal better.
As for which way top or bottom the 2 seals go???
I put the rubber at the bottom and the filler join at the top.
Anyway your way above is the best way
