Would You Be Happy With This?
13 replies to this topic
#1 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 18 July 2023 - 06:04 PM
Purchased a Rear Subframe brand new with a "Phosphate coating" and this is how it arrived -
Flaking off in sections. Sort of put Me off as there's no point in painting the epoxy mastic primer onto a surface that's Flaking :-(
Attached File  20230718_164731.jpg   18.94K   5 downloads
Poor coverage
Attached File  20230718_164734.jpg   16.44K   3 downloads
Attached File  20230718_164819.jpg   24.34K   0 downloads
Attached File  20230718_164833.jpg   24.7K   0 downloads
Attached File  20230718_164836.jpg   28.66K   0 downloads
No coverage / bare metal
Attached File  20230718_164826.jpg   32.58K   1 downloads
Attached File  20230718_164830.jpg   22.32K   1 downloads
Should this hole be round??
Attached File  20230718_164936.jpg   15.95K   5 downloads
Also How do you tell if its a Phosphate coating or just grey primer?
#2 Spider
  • 15,684 posts
Posted 18 July 2023 - 07:16 PM
The few new subframes I have bought, I only ever looked at the coating, where it it might be, as something to stop (or reduce) any rust while in storage. I've always had them blasted, then painted them in my favorite coating at the time.
#3 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 19 July 2023 - 06:10 AM
My impression from the advert was it was going to be properly coated in an Anti Corrosion Phosphate coating ready to paint ontop of :-(
Will contact the seller and if get no where will just have to sand and paint it in Epoxy Mastic
It was from Minis-R-Us
Edited by Steve-O 2014, 19 July 2023 - 06:12 AM.
#4 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 19 July 2023 - 06:51 AM
Wouldnt accept that.
#5 Vanman20
Vanman20
  • 274 posts
Posted 19 July 2023 - 09:10 AM
I'd have that blasted and powder coated
#6 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 19 July 2023 - 10:27 AM
Yea but that's adding another £150 or so to the cost. The idea of getting a one treated with a Phosphate primer was so it was ready to apply an Epoxy protection to.
Also been recommended not to powder coat as once it chips it's going to be a nightmare and a easy access for water and corrosion
#7 Steve-O 2014
Steve-O 2014
  • 312 posts
Emailed then to see what they say
#8 DeadSquare
DeadSquare
  • 3,375 posts
Posted 19 July 2023 - 11:17 AM
I put mine in a pile of straw and burn off the paint so that I can get it 'hot-dipped' galvanised, and then paint it with a couple of coats of white Hammerite.
#9 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 19 July 2023 - 11:44 AM
Mmm no I wouldn’t be happy with that so going back to the seller is the right way to go.
However if you hit a wall with them you could go down the small claims route or take the hit, get the whole thing media blasted then apply your coating from there.
I have harped on about some of these so called e coats etc from manufacture and to be honest you have no idea what has actually been done, how and where they have been stored etc. so no matter whether it’s a Heritage product or magnum I remove any coating back to bare metal and then go from there.
#10 KTS
KTS
  • 2,490 posts
Posted 19 July 2023 - 12:15 PM
if it's the drilling for the inner end of a front support pin, then i would expect a neat round hole to locate the pin correctly
#11 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 20 July 2023 - 06:08 AM
Seller is booking a collection for it so full refund and free return :-)
#12 greenwheels
greenwheels
  • 691 posts
  • Local Club: Mini Fixers
Posted 20 July 2023 - 08:51 AM
Sounds a way to end up with a distorted subframe!
I am a fan of Hammerite though
#13 ings
ings
  • 202 posts
Posted 20 July 2023 - 09:04 AM
the best money you can spend on a mini is a nice looking rear subframe. I would also sandblast a brand new frame,then a layer of zinc rust protection, then powder coating and a layer of wax in to the hollow spaces.
Then you never have to worry about the rust on the rear again and if you sell the car you get the costs of the powder coating 3 times back.
#14 coopertaz
coopertaz
  • 907 posts
  • Local Club: a-series-magpies
Posted 28 July 2023 - 10:38 AM
fitted powder coated subframes but you do need to cavity wax thoroughly, fitted this one purely for looks|
