I have just replaced my timing cover oil seal and gasket cover using one of the newer type gaskets with the blue sealant between the bolt holes and did not use any sealant.
Guess what - it leaks!
Have I made a school boy error and should have used sealant?
I have a spare standard gasket in the garage so I can strip it all down again and replace and use some sealant.
Is Loctite SI 5980 the best one to use?
Could kick myself as I am pleased that engine is now getting up to temp after replacing thermostat with an 88f one but also so annoyed as I need to strip it all down again!
