Clutch Noise
8 replies to this topic
#1 sam138
sam138
  • 509 posts
Posted 23 July 2023 - 05:44 PM
Just wondering if anyone can help, I’ve just finished a rebuild 1380 engine with a refreshed gearbox and converted to a pre verto clutch which is a MED ST2 kit. As per the below video I’m getting this noise coming from the clutch at idle and gets louder if I rev the car at idle but disappears if I drop the clutch. Car drives great apart from some judder from the clutch on pull away and very tight to get into gear. Any ideas please ?
https://youtube.com/...s?feature=share
Edited by sam138, 23 July 2023 - 05:45 PM.
#2 imack
imack
  • 2,167 posts
Posted 23 July 2023 - 05:49 PM
Have you got a clearance set between the release arm and the little 7/16" adjustment bolt head?
#3 sonscar
sonscar
  • 3,026 posts
Posted 23 July 2023 - 06:23 PM
Wrong size bolt hitting clutch?Steve..
#4 sam138
sam138
  • 509 posts
Posted 23 July 2023 - 06:35 PM
Few pics below during the rebuild
I did also adjust up the clutch arm etc
Although I used the clutch oil seal tool I’ve seen it’s leak a few spots of oil so I will be taking the clutch off again which is a pain but can’t see this has anything to do with this noise.
Attached File  932EE1B3-E554-4CA3-990A-A02CF0D16443.jpeg   142.42K   1 downloads
Attached File  C8BFA1C5-C4A3-4256-8D5E-55A1AEC7A449.jpeg   142.12K   1 downloads
Attached File  26A2AED5-59F0-41B6-9904-F32A9F9DD4C4.jpeg   149.43K   0 downloads
Attached File  702E71EE-517D-4242-BA57-7A14D2405FC7.jpeg   172.66K   0 downloads
Edited by sam138, 23 July 2023 - 06:38 PM.
#5 sam138
sam138
  • 509 posts
Posted 23 July 2023 - 06:45 PM
I’ll try adjusting the clutch arm up again, could this be causing the issue if it’s not correctly adjusted ? If anyone could advise on their method to adjust this please ?
Edited by sam138, 23 July 2023 - 06:46 PM.
#6 growlerbearnz
growlerbearnz
  • 50 posts
  • Local Club: Mini Car Club of Auckland
Posted 25 July 2023 - 01:21 AM
After much discussion about this one, my current method is:
-Disconnect the return spring
Adjust the overthrow stop nuts (Prevents the clutch release from moving too far and janking up the crankshaft thrust bearings)
-Unwind the large stop nuts (on the end of the plunger)
-Slip a pipe over the clutch arm (for extra leverage) and pull the arm away from the engine as far as it will go. (Releasing the clutch, and then further)
-Screw the stop nut in until it touches the wok.
-Release the arm and remove the pipe.
-screw the stop nut in another half a turn, then lock it with the lock nut.
Then adjust the free play (ensures the release bearing is pulled away from the clutch when not in use) :
-Using light finger force only, pull the clutch arm out until it stops and hold it there.
-Wind out the stop bolt until it just touches the arm
-Wind the bolt back in until there's 0.015" (0.4mm) clearance between it and the arm (while still lightly pulling the arm out)
-Lock the bolt using the lock nut and check the clearance
Reattach the return spring and enjoy.
(And yes, if the release bearing is touching the clutch all the time (not enough clearance) then it might be rattling as the engine runs. Usually you'd see/feel the plunger moving around as the engine turns, but if the engine's shaking it might be hard to see.)
Edited by growlerbearnz, 25 July 2023 - 01:23 AM.
#7 GraemeC
GraemeC
  • 7,439 posts
Posted 25 July 2023 - 11:20 AM
I suspect engine mount bolts are a fraction too long.
#8 sam138
sam138
  • 509 posts
Posted 04 August 2023 - 08:13 PM
Thanks for the reply’s, I’m due to remove the clutch tomorrow and sort the leaking oil seal and inspect the clutch for any issues.
With a pre verto clutch do you have to dismantle it to then pull the flywheel off ? Just worried about the balancing being disturbed.
I used to have a verto which you pull off in one piece.
Edited by sam138, 04 August 2023 - 08:14 PM.
#9 KTS
KTS
  • 2,451 posts
Posted 04 August 2023 - 10:50 PM
No; just remove the thrust plate from the top of the diaphragm to access and undo the flywheel bolt
