Hydrolastic Schrader Valve Core
4 replies to this topic
#1 1967coopers
1967coopers
    Starting My Mini Up
  • 3 posts
Posted 25 July 2023 - 01:17 PM
Hello hope I can Get a view on my subject, having just rebuilt a 1967 Cooper S I am getting near the stage of repressurising the suspension but after removing the old Schrader valve cores they are shot so need replacing, after reading a few adverts on Ebay people seem to be selling "special" Hydrolastic valve cores so I assume they are higher pressure cores ? if so are lorry cores suitable ? many thanks in advance.
#2 eric67
eric67
  • 119 posts
Posted 25 July 2023 - 04:52 PM
I use standard tyre valves in mine and they work fine. I guess that in operation the additional pressure is acting to keep the valve closed so nothing special is needed. There are many designs of valves available so I would pick something that looks similar to your existing ones.
#3 nicklouse
  • 18,738 posts
Posted 25 July 2023 - 04:54 PM
Can I ask a question. What pressure do the systems run at? I have no idea.
but MTB air shocks use standard schrader valves and cores and they run a quite high pressures with big leverages applied. Not to mention ac systems, fuel injection systems.
there are different diameters and I think a small change to the core length but I would be happy fitting one that fitted.
others might have better info.
#4 Ethel
  • 26,136 posts
Posted 25 July 2023 - 05:33 PM
The pumps have gauges, but you pump it up to raise the body to a specific height.  Don't think I ever looked at the pressure, but it a tyre footprint looks a similar area, so tyre pressure x suspension leverage can't be far off  :unsure:
#5 Spider
  • 15,219 posts
Posted 25 July 2023 - 07:06 PM
They are just a standard Schrader Core, same as in 99.99% of the cars on the road. It's the small size of the valves that let them cope with high pressures and they are made from materials that don't rust or readily corrode.
Static, they are just under 300 PSI off hand.
