Oil Thrower Missing - More Timing Cover Woes
4 replies to this topic
#1 Speedymad
Speedymad
  • 92 posts
Posted 25 July 2023 - 07:19 PM
Sorry for ore posts on my timing cover woes.
Just watched classic mini workshop video on replacing seal and gasket and he mentions the oil thrower washer, but I do not have one fitted and certainly nothing came out when I first stripped it.
I am running mini spares duplex gears but assume that there should be an oil thrower in place?  Is there any reason not to fit one?
I want to do everything to try and prevent future oil leaks and this would seem sensible to fit.
Many thanks
#2 nicklouse
  • 18,998 posts
Posted 25 July 2023 - 07:46 PM
IIRC some chains did cause issues with the UK spec oil thrower as they had a joining clip which could cause contact issues so people binned the thrower.
#3 Speedymad
Speedymad
  • 92 posts
Posted 25 July 2023 - 07:49 PM
Thanks as always Nick, much appreciated.
Might order one for the sake of a few quid and see if it is catching.
#4 imack
imack
  • 2,372 posts
Posted 25 July 2023 - 07:57 PM
I've run with and without the oil thrower with no issues. MED told me to run without the thrower which I did for a number of years. I now run with one again mainly as with it fitted it gave perfect crank, water pump and alternator pulley alignment.
#5 Speedymad
Speedymad
  • 92 posts
Posted 25 July 2023 - 08:02 PM
thanks for the reply.
just had a quick look at the chain and can’t see a joining pin so hopefully can re fit
