Grating Sound !
5 replies to this topic
#1 mrmeds
mrmeds
  • 266 posts
Posted 29 July 2023 - 05:19 PM
Get a metallic grating sound that seems to come from rear left hand side if  doing a hard right turn ( like going right on a mini roundabout )- any ide what it could be - am I thinking subframe , shock absorber , other suspension or wheel ?
thanks folks
has just gone through mot with no advisories
#2 ThermalEvent
ThermalEvent
  • 123 posts
  • Local Club: n/a
Posted 29 July 2023 - 05:45 PM
I had a similar sound and it turned out to be the brake drum contacting the aftermarket back plate. Removed the drum and found metal filings as well as bare metal on the back plate lip. Took a grinder/flap wheel to the lip and jobs a good'un.
#3 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 30 July 2023 - 04:12 AM
Loose exhaust?
#4 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 30 July 2023 - 04:20 AM
Check the bearing and hub nut first i would say..
#5 andyapanel
andyapanel
  • 642 posts
Posted 30 July 2023 - 06:43 AM
A return spring broke once. It made a horrible noise.
#6 mbolt998
mbolt998
  • 433 posts
Posted 30 July 2023 - 07:14 AM
thanks folks
I also think it's brake drum. Mine does a bit of squeaking when turning left but which has got much better with just driving it a bit. I have some new drums and shoes to go on so plan to have a look at some point.
