Hand Brake Cable
Posted 05 August 2023 - 07:56 AM
Posted 05 August 2023 - 08:09 AM
Under the car, adjusting on the splitter plate that pulls the rear cable.
Posted 05 August 2023 - 12:52 PM
I think you will find cable adjuster is inside car.
Posted 05 August 2023 - 01:55 PM
From the layout shown here it appears to be under the car, but then the item 13 is described as being at the front, so fair enough, inside the car it is.
http://minispares.co...les.aspx?1~9~83
Posted 05 August 2023 - 02:13 PM
I agree the illustration does look confusing! perhaps early models were like that? i have 4 late mini's and they all have adjusters at handbrake lever inside. make sure drums are adjusted before adjusting cable.
Posted 05 August 2023 - 02:36 PM
It would probably work either way. I'd sooner have the thread on the inside where it's less likely to corrode & seize and you can adjust the lever pull at the lever.
