Good afternoon folks,
I am still in the process of rebuilding this mini, after much struggle I’ve got the short block together and cylinder head on but I’m now running into problems with the gearbox.
I am trying to set up the idler gear end float and it’s massive - like over 0.8mm
I thought initially that it could be excessive wear in the flywheel housing but on closer inspection I think it’s the gearbox housing itself. For reference gearbox is 22A1522.
Looking at the face where the idler thrust washer runs against it looks heavily worn (read aluminium looks to have overheated) and the oil channels which I’ve seen typically here are missing. Furthermore, when I put a straight edge across its face it is very much not flat. I’ve tried to include some photographs to illustrate the issue.
Do I need a new gearbox housing or is this the resolvable in a way I’m missing?
Any help is much appreciated.
Cammy
Edited by Cammy46, 07 August 2023 - 03:25 PM.
