Rear Inertia Seat Belts
5 replies to this topic
#1 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 26 August 2023 - 02:33 AM
To fit some rear inertia seat belts in a 79 saloon where are the fixing points?
Can I have pictures of the top mount. Is that a factory fitting. Not something that can be added?
Edited by IronmanG, 26 August 2023 - 02:47 AM.
#2 Ethel
  • 26,055 posts
Posted 26 August 2023 - 06:50 AM
Don't think such a thing exists, as a factory fitting. They were only static belts, mounting to the C pillar & bottom of the seat back. The MPI inertia reels mount to the rear wheel arch. People have fitted horizontal  reels, as used on soft tops & Series Lannies,  to the parcel shelf. It would need some fabricated reinforcement & wouldn't be great for anyone whose shoulder is higher than the seat back.
#3 IronmanG
IronmanG
  • 1,253 posts
Posted 26 August 2023 - 07:47 AM
https://www.minispar...|Back to search
Does it need this
#4 stuart bowes
stuart bowes
  • 2,228 posts
Posted 26 August 2023 - 07:58 AM
That's the c pillar fixing point and I believe there are two slightly different types because the window hole changed slightly depending on age. The guy at Somerford mini explained it to me when I ordered some
The same place also sells the fixing brackets for the wheel arch. Easiest to weld in with the rear quarters off but possible without if you don't mind welding at tricky angles in tight spaces. Check out some other builds to make sure welding the right one to the right side and at the right height but a bit of logic you can work it out
Therefore the reel will be in the storage bin and the pivot point over the shoulder fixes to the c pillar
Edited by stuart bowes, 26 August 2023 - 08:03 AM.
#5 IronmanG
IronmanG
  • 1,253 posts
Posted 26 August 2023 - 08:08 AM
Yep ok. So the fixing points were only standard later and they need welding in on C pillar
#6 stuart bowes
stuart bowes
  • 2,228 posts
Posted 26 August 2023 - 08:17 AM
Basically yeah the c pillar piece is also a general strengthening piece as well I guess because mine had them including the threaded fixing point but still only came with lap belts and no reel fixings in the bins
I suppose that was when they did 3 points as an option but were only fixed not reels
Edited by stuart bowes, 26 August 2023 - 08:20 AM.
