Head Gasket Cracked
4 replies to this topic
#1 dolli93
dolli93
  • 34 posts
Posted 29 August 2023 - 12:06 PM
Been having some engine problams with my 91 rover mini 1275. got a camera down the spark plug hole and there was some fluid on the pistons, so need to replace it. Seems to be a lot of gaskets out there. Was told its always best to use original gasket. Guessing its probably not in production anymore. So my question is, what head gasket do you recommend that i use.
#2 Tones61
Tones61
  • 434 posts
Posted 29 August 2023 - 12:07 PM
bk450 gasket ;-)
#3 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 29 August 2023 - 12:29 PM
As above if you can get one
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,379 posts
  • Local Club: Amoc
Posted 29 August 2023 - 01:00 PM
Remember to order oil and coolant.
Also your head may need to be skimmed and your bore will need cleaned out..
Always something with a mini.....
#5 Cooperman
  • 23,326 posts
Posted 29 August 2023 - 06:04 PM
Yes, BK 450 is the one you need.
