Steering Wheel Won’T Come Off
11 replies to this topic
#1 Pippin-the-peridot-mini
  • 12 posts
Posted 30 August 2023 - 04:24 PM
Hi,
I have been following the Haynes manual, hitting the back with a mallet, the steering wheel has never been removed so asked a friend and he said that I would need a lot of brute force, I have been tugging at the wheel and shaking it whilst my helper has been tapping the centre but still has not shifted.
Any advice what to try next?
#2 nicklouse
  • 18,998 posts
Posted 30 August 2023 - 05:23 PM
First thing put the nut back on a few turns or you will hut yourself.
you could get a puller on it. But it does depend on the wheel.
keep at it with a soft faced mallet and brute force.
#3 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 30 August 2023 - 05:40 PM
Always a nightmare to get off when they have been on for many moons....
I always find that rude force works best.. just try keeping the wheels straight or mark the wheel and mark the column so it goes back in right is place.
#4 greenwheels
greenwheels
  • 691 posts
  • Local Club: Mini Fixers
Posted 30 August 2023 - 05:50 PM
Wrap a strip of rag 1/2 inch wide around the stub and soak it in a good penetrating oil overnight. (not WD40)
As nicklouse says put the nut back on a few turns 'because when it does come off it will try to break your nose!!
Grip the wheel at 1/4 past 9 position and wobble it up and down alternate sides in the direction of the shaft. It will come off.
#5 Homersimpson
Homersimpson
  • 851 posts
Posted 30 August 2023 - 07:29 PM
I would screw the nut back on until the top of the column is level with the top of the column (to prevent damage to column thread) and then hit it with an ordinary hammer while pulling the wheel up towards me.
You need the sharp crack of steel on steel, I doubt a mallet is going to do what you need.
#6 Steam
Steam
  • 933 posts
  • Local Club: Victorian Mini Club
Posted 31 August 2023 - 06:21 AM
I find that bracing both knees on the wheel close to the hub to push up on the wheel while belting the half screwed on nut works.
Lube oil or spray and keep the nut half on unless you want a broken nose.
#7 sonscar
sonscar
  • 3,198 posts
Posted 31 August 2023 - 06:57 AM
I find a puller works,tighten,brew up,tighten,contemplate life,tighten,go to bed.Off in the morning,Steve..
#8 Rorf
Rorf
  • 866 posts
Posted 01 September 2023 - 06:39 PM
Hit the back of the steering wheel with a BFH :D
#9 coopertaz
coopertaz
  • 907 posts
  • Local Club: a-series-magpies
Posted 05 September 2023 - 11:09 AM
nut on, knees behind steering wheel and push while belting middle with normal hammer. always worked for me
#10 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 05 September 2023 - 04:34 PM
Any luck yet or are you currently getting a new nose in the hospital?
#11 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 06 September 2023 - 10:24 AM
Penetrating fluid! I tend to put it on and leave it over night then wobble it at the 1230 position and then 0915 position several times. Problem from factory is they don't put anything on the splines to stop corrosion.
#12 coopertaz
coopertaz
  • 907 posts
Posted 07 September 2023 - 10:06 AM
they prob hope it will corrode together and stop it comming of the same as column to rack splines
