Has anyone installed a front suspension limiting strap to the front suspension? I’ve put red spot cones, modified hilos in and lowered type shocks, but whilst the cones settle the cones are a bit too loose for liking when on full droop so thinking adding limiting straps would be an idea.
Question is how did you mount? Was thinking of looping a strap around the top mount and then to the other side of shock bolt. However standard straps seem to large and unable to found anything smaller.
Edited by Robbo12, 03 September 2023 - 02:25 PM.
