Oil Cooler Option
2 replies to this topic
#1 croc7
croc7
  • 878 posts
Posted 04 September 2023 - 03:49 AM
 All components in the cooling system are in great shape but I would like to see the temperature run a little cooler in hot weather so I am considering installation of an oil cooler to help with controlling water temp.
How much reduction of water temp could I expect to see?  I've been told that one isn't needed on a street car as it would cause oil/water temps to be too low but I had one in my '67 Cooper S back in the '70's and don't recall any temp issues at all even when climbing mountain passes.
#2 nicklouse
  • 18,998 posts
Posted 04 September 2023 - 06:43 AM
First what temp is your oil at?
oil that is too cool causes more ware than oil that is a little too hot.
cooling the oil will have little effect on the engine temp.
If you do fit one please also fit a thermostat so that it only cools the oil when it is too hot.
#3 Steam
Steam
  • 933 posts
  • Local Club: Victorian Mini Club
Posted 04 September 2023 - 07:59 AM
A cooler thermostat will do the job. As Nicklouse says you do not wnat to cool the oil too much and it will have little effect on overall engine temp anyway.
