Bypass Hose, Jubilee Clips?
4 replies to this topic
#1 Speakjava
Speakjava
  • 15 posts
Posted 04 September 2023 - 04:55 PM
After the battle of the sheared engine mount bolt, we finally got our new engine started!
First problem was an overflowing carb bowl but a new valve and gasket sorted that.
Unfortunately, we have a coolant leak where it's not obvious where it's coming from. I suspected the water pump gasket but when looking for signs of this I noticed that the bypass hose doesn't have any jubilee clips on it.  Is this normal?  I seem to remember from my original 71 clubman that it had clips (but that was 40 years ago so I may be wrong).
My other suspicion is a leaky head gasket, which I'm really hoping it isn't because I don't really want to have to pop the head off just for this.
Thanks in advance.
#2 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 04 September 2023 - 05:59 PM
Bypass should have clips ...
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 04 September 2023 - 06:29 PM
Bypass hose should have clips
#4 68+86auto
68+86auto
  • 1,345 posts
  • Local Club: Queensland Mini Car Club
Posted 05 September 2023 - 03:08 AM
Definitely needs clips.
#5 Ethel
  • 26,580 posts
Posted 05 September 2023 - 10:42 AM
The proper clips fit the hose better https://www.minispar...sic/3H2963.aspx
You could replace the screws, or find similar clamps, with socket heads to make tightening/undoing easier. But, as you're unlikely to replace the hose without removing the the head or pump too it's not such an issue
