Can't think why this would be there?
Also odd marks on thermo housing. Apparently the head has "had some work done" But was it by Baron Frankenstein??
Edited by Cyclops63, 19 September 2023 - 08:58 PM.
Posted 19 September 2023 - 08:52 PM
Posted 19 September 2023 - 08:57 PM
Posted 19 September 2023 - 08:58 PM
Posted 19 September 2023 - 09:35 PM
Please note it is not a standard pop rivet but a closed pop rivet so it seals the drilling.
Posted 20 September 2023 - 07:18 AM
Posted 20 September 2023 - 10:37 AM
did wonder what this was for but just painted over it. as you say if it aint broke
Posted 20 September 2023 - 10:45 AM
The early heads had brass plugs, I'm not sure when the pop rivet plugs were fitted, I'd say from the mid 80's.
it seems fine. "If it aint broke..."
I'm not sure what your project is here,,,, but,,,, I gotta say,,,,,,
I always pull the plugs. There'll be a blind pocket there that will hold crud and can't be otherwise reached in to.
You can early re-fit new plugs or a Rivet of the correct type, sealant is wise. I tape the holes and fit screwed plugs, then next time, it's dead easy.
