Who Makes The Thickest Head Gasket ?
5 replies to this topic
#1 DeadSquare
DeadSquare
  • 3,188 posts
Posted 20 September 2023 - 02:19 PM
Last month a chap called and asked if I knew what the noise was in his daughter's 40+ year old, 'barn-find', Mini.  I didn't really need to go 100 yards to confirm that with out lead in the fuel, I would diagnose 'pre-ignition'.
I have done the usual timing / mixture things, but it's still there, so last night I removed the head, expecting to see a massive de-coke needed.
Instead, the head is nicely profiled with polished ports and larger valves, but heavily shaved.  It is also obvious that although the block and the log book say 998, it actually has an 1100 crank.  I haven't measured the combustion volume, but It looks as though the head came from a hot 850 and I recon that the C/R could well be over 12:1, so it needs a decompression plate or maybe three very thick gaskets.
#2 whistler
whistler
  • 1,818 posts
Posted 20 September 2023 - 04:03 PM
I know they're expensive but Cometic make various thicknesses in head gaskets.
#3 Shooter63
Shooter63
  • 1,079 posts
Posted 20 September 2023 - 04:55 PM
The Victor Reinz gasket has around 3.5cc capacity, may be a bit more, which is I believe the biggest without going down the specialist route. Can you not ease the chambers to gain more capacity?
Shooter
#4 DeadSquare
DeadSquare
  • 3,188 posts
Posted 20 September 2023 - 10:20 PM
Thank you for your suggestions.
I used to have, or can't find, a large ex-WD  "Q-Max" 2.5" , punch and die hole cutter, that with plenty of lubrication would just cut 1/8" aluminium.
The 63.5mm hole was ideal for decompressing supercharged, small bore A series.
#5 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 21 September 2023 - 12:28 AM
Vmax sells decompression plates for small bores. I haven’t been able to find any thick Cometic small bore ones
You can also use two head gaskets
Or another option is a good supply of octane booster
#6 mini13
mini13
  • 3,811 posts
Posted 21 September 2023 - 09:24 AM
yeah... i would try to avoid thick gaskets if possible, but that said i have run 2 gaskets on a 1380 turbo motor with no problems
