Best Abrasives?
3 replies to this topic
#1 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 20 September 2023 - 09:19 PM
Just starting a new project and will be using a never-ending amount of the usual various types of abrasives until I get to the painting stage. So I'll be using flapper discs, cutting discs, finger belt sander belts, paint and rust scale discs etc etc. Bear in mind this is a budget home/hobby job although saying that good quality products inevitably end up saving money! Any recommendations on makes and in the case of a paint/rust scale stripping disc type. Cheers!
#2 Tupers
Tupers
  • 4,160 posts
Posted 20 September 2023 - 09:26 PM
Norton, Klinspor and Abracs are all great for strip, flap and cutting discs.
#3 68+86auto
68+86auto
  • 1,036 posts
  • Local Club: Queensland Mini Car Club
Posted 21 September 2023 - 02:48 AM
3M or Norton. I have tried a few others and they definitely dont last as long. That is definitely the case for the finger sander belts.
I bought boxes of Smirdex 6" sanding discs, once I go through them I will switch to 3M.
#4 stuart bowes
stuart bowes
  • 2,287 posts
Posted 21 September 2023 - 09:15 AM
I've been buying generic zirconium power file belts from Amazon and to be honest they don't last ages, but then they're also cheap
https://www.amazon.c...le?ie=UTF8&th=1  @ £1.15 ea currently
whereas the 'good' ones can be like 3 quid each ?   that's what puts me off but maybe they're just so much better that it's worth it
they are hit and miss, one belt will do easily 20-30mins of work or even an hour (depending what you're doing with it) the next one will last 2 mins.. if you're careful you can keep towards the longer end of that on average, I tend to knock the tops of the welds down initially with a grinder disc or flap, then do the finishing work carefully with the belt because you can be more accurate with the tip
lower grit numbers obviously remove more but don't last as long, higher grit last longer but take longer (or are better for finishing..) swings and roundabouts
I did get one batch where every single one just literally snapped after 10 seconds, I put them all in a bag and sent them back and got the money back, so that's one benefit of amazon, easy returns and credits (other than obviously the hassle and wasted time which was annoying)
As I get to the end of the welding and cutting phase and all the 'rough' work is done there will be less sharp corners and edges left and they'll start lasting longer I guess
Edited by stuart bowes, 21 September 2023 - 09:20 AM.
