Can You Paint Over Existing Primer?
7 replies to this topic
#1 np90
np90
  • 47 posts
Posted 23 September 2023 - 11:01 AM
Hi all quick question just doing a spot repair round the front near the headlight.. I've applied primer to bare metal areas where it was bubbling, but I'm going a bit further to blend the paint in a bit better.. Do I need to sand down to metal and reprimer or can I 400 grit down to the existing primer finish with 600 then apply base coat??
#2 DeadSquare
DeadSquare
  • 3,205 posts
Posted 23 September 2023 - 09:56 PM
I'm not a paint expert, but I have always rubbed down an area around the patch to be painted, to remove any car polish and to give the next coat something the grip on to.
It doesn't work 100%  of the time, some car polish gets further into the paint than one thinks, and the new paint forms into little balls.
There is a very expensive additive that overcomes this, but I cannot recall the name.
#3 Homersimpson
Homersimpson
  • 840 posts
Posted 23 September 2023 - 10:44 PM
Once the primer has been flatted I then run over the paint around the area with a polishing mop with a course compound to provide a bit of key.
I then clean the whole area with panel wipe, tack it off and paint it.
Make sure you don't paint upto a hard edge unless its a panel edge/seam as its hard to blend in a straight line.  Its much better to say mask up the whole car except the wing and front panel, paint what you need to and then flat and mop afterwards to blend it all in.
#4 np90
np90
  • 47 posts
Posted 24 September 2023 - 01:27 PM
Im trying to flat it down to primer with a block but it's a bit awkward in that area and it's gone to a bit of metal in a couple of small places... to be honest I've always primered but was hoping to get away without primering this and blending straight over... I've done the other side and took it to metal as there was rust/ bubbling so took it all back..
However if I apply base coat over this.. Will it show in daylight ?..
#5 np90
np90
  • 47 posts
Posted 24 September 2023 - 01:34 PM
Still sanding down but essentially applying base coat on that.. Will it show..
#6 Vanman20
Vanman20
  • 274 posts
Posted 24 September 2023 - 02:32 PM
Basically,any time you break through a coat of paint to the substrate you should primer
#7 Homersimpson
Homersimpson
  • 840 posts
Posted 24 September 2023 - 06:49 PM
In theory yes but it if its only a small area its normally ok, that said in the picture above if the large white patch at the bottom left next to the seam is filler than an area that size needs primer over it.
#8 68+86auto
68+86auto
  • 1,029 posts
  • Local Club: Queensland Mini Car Club
Posted 24 September 2023 - 10:01 PM
Read the TDS of all products being used.
