Heater Matrix Bulkhead Seal/grommet
11 replies to this topic
#1 SteadyEddie
SteadyEddie
  • 26 posts
Posted 25 September 2023 - 10:05 AM
Hey there!  I'm getting a leak from rain water through the bulkhead. (definitely rain rather than the hose, it only happens when it's wet and my coolant level isn't going down!). Is there a seal or grommet that should be here but is missing?
#2 Chris1275gt
Chris1275gt
  • 958 posts
Posted 25 September 2023 - 10:41 AM
http://www.minispare...ic/grommet.aspx
Edited by Chris1275gt, 25 September 2023 - 10:44 AM.
#3 KTS
KTS
  • 2,453 posts
Posted 25 September 2023 - 11:03 AM
it looks like you need a new bulkhead plate
http://www.minispare...ts/ALA7530.aspx
#4 Ethel
  • 26,016 posts
Posted 25 September 2023 - 11:45 AM
Is that engine steady bracket in use?
Looks like it'll create a few clearance issues. The company formerly known as DSN have some tasty solutions, with not so palatable prices,
The least effort alternative could be a generic bulkhead hose fitting off of Fleabay
https://www.carbuild...k/nylon-joiners some niceness here too
#5 SteadyEddie
SteadyEddie
  • 26 posts
Posted 25 September 2023 - 12:31 PM
The steady bracket isn't in use no. The bracket was there when I got the car but the steady wasn't. I did buy one, but it didn't seem to fit (almost like it needed to be a bit longer to get over the back of the manifold), and having seen people's comments on here that they're not that useful I thought I'd leave it off.
Those are some very nice looking steadies on the link you sent... May have to invest in one of those. I went for the minispares one as that's where I've been getting my parts from so far. Have you used the ones you linked?
Edited by SteadyEddie, 25 September 2023 - 12:33 PM.
#6 Lplus
Lplus
  • 911 posts
Posted 25 September 2023 - 12:37 PM
It looks like the plate has been hacked to allow the pipe to pass beside the steady bracket, so removing the bracket as well as fining a plate might help.  where is the water coming from?  the wiper boxes should have plastic seals around them and the wiper arms should cover the spindles for the wipers.
#7 sonscar
sonscar
  • 3,028 posts
Posted 25 September 2023 - 12:38 PM
Is the seal on the scuttle panel at the back of the bonnet good?Steve..
#8 Chris1275gt
Chris1275gt
  • 958 posts
Posted 25 September 2023 - 12:59 PM
Become a member for £5 and get 7.5% off at minispares.
#9 SteadyEddie
SteadyEddie
  • 26 posts
Posted 25 September 2023 - 01:08 PM
The scuttle seal looks alright to me, but will certainly get myself a new plate and the grommet from that minispares link. After getting a membership! Wish I'd done that sooner, thanks Chris!
#10 Steam
Steam
  • 803 posts
  • Local Club: Victorian Mini Club
Posted 26 September 2023 - 02:19 AM
Despite the seals on the bulkhead needing replacing, there should not be water getting onto the bulkhead in the first place. Could be washer fluid, or from the bonnet seal or from the wiper bushes.
#11 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 26 September 2023 - 06:56 PM
You need the plate that KTS suggest also this gasket
Attached File  IMG_1673.png   223.9K   0 downloads
even these may not seal it off to well and you may need to put a bit silicon around the hose.
#12 Ethel
  • 26,016 posts
Posted 27 September 2023 - 01:19 PM
No, not used any DSN  S-CAN stuff. Had a thermostat side steady bar on a Mini back in the day & a couple of sheared standard engine steady bolts, so I think they're a worthwhile addition. Mine was probably homespun from threaded rod & tie rod bushes.
