Water From Block Beneath Water Pump
13 replies to this topic
#1 Cyclops63
Cyclops63
  • 82 posts
Posted 25 September 2023 - 07:27 PM
Hi all. Just reinstalled my entire cooling system on 79 850. It was watertight previously. Now there is water seeping from a hole on the face of the block directly below the water pump. I've never even noticed this hole before. Clues please...
#2 Cyclops63
Cyclops63
  • 82 posts
Posted 25 September 2023 - 07:29 PM
Struggling to upload pic...
#3 Cyclops63
Cyclops63
  • 82 posts
Posted 25 September 2023 - 07:32 PM
Pic
#4 KTS
KTS
  • 2,454 posts
Posted 25 September 2023 - 09:17 PM
It looks like the leak is coming from above and tracking down the backplate and pooling there
The hole you're referring to is the end of an oil gallery which will have a plug in it
#5 nicklouse
  • 18,657 posts
Posted 25 September 2023 - 09:20 PM
That’s nothing to do with water. It’s a cap for one of the oil galleries.
#6 Cyclops63
Cyclops63
  • 82 posts
Posted 25 September 2023 - 10:52 PM
Thsnks, chaps. It certainly had me stumped. I'll remove the water pump tomorrow and investigate further. Drat!Just when i was putting it back together...
#7 Designer
Designer
  • 610 posts
  • Local Club: LSMOC
Posted 26 September 2023 - 05:07 AM
That's the joy of Minis they let you solve one problem only to create another. They just want to make sure you know them inside out and every nook and cranny.
I think they work on the reverse of "Measure twice cut once".
#8 Spider
  • 15,038 posts
Posted 26 September 2023 - 06:02 AM
If the pump and hoses are not new, some corrosion can occur between them. When that's disturbed, without giving them both a good cleaning, they don't always re-seal and you can end up with small leak(s).
#9 Cyclops63
Cyclops63
  • 82 posts
Posted 26 September 2023 - 08:04 AM
It's new hoses throughout, so hopefully there shouldn't be a problem there. Im suspecting the drain hole on the underside of the water pump is acting up having been "disturbed" perhaps. Also, its all new gaskets and everything is nice and tight.
#10 coopertaz
coopertaz
  • 798 posts
  • Local Club: a-series-magpies
Posted 26 September 2023 - 09:32 AM
from pic that is def. comming out above and running down plate. drain hole in bottom of pump!? you mean the tell tale hole?
#11 nicklouse
  • 18,657 posts
Posted 26 September 2023 - 09:37 AM
That tends to be on the top of the pump.
#12 coopertaz
coopertaz
  • 798 posts
Posted 26 September 2023 - 09:39 AM
what drain hole is he on about then, or am i being dumb!
#13 Cyclops63
Cyclops63
  • 82 posts
Posted 26 September 2023 - 10:28 AM
Yes not "drain" hole but on the underside of the water pump. Earlier pumps had it on top, I believe.
#14 Cyclops63
Cyclops63
  • 82 posts
Posted 26 September 2023 - 06:53 PM
So, it transpires the water was seeping out from between the block snd the bottom of the water pump. A tiny chip in the water pump facing seemed to be enough to cause it. Replacing it with a large impeller model. Might as well improve it if I have to replace it...
