Diff Side Cover Bush
5 replies to this topic
#1 gaspen
gaspen
  • 949 posts
Posted 27 September 2023 - 04:18 PM
Hello
Today a dissassembled the diff, the bushes have to be replace/machining
On the picture you see the old bush
Shouldn't the hole in the bush aligned one of the oil grooves in the housing ?
Attached File  20230927_114909.jpg   25.73K   0 downloads
#2 stoneface
stoneface
  • 369 posts
Posted 27 September 2023 - 08:23 PM
https://www.theminif...h/#entry3660265
#3 gaspen
gaspen
  • 949 posts
Posted 28 September 2023 - 06:18 AM
#4 ac427
ac427
  • 678 posts
Posted 28 September 2023 - 12:19 PM
I think they have to be reamed to size when replaced. However, i cannot remember what size they need to be reamed to?
#5 Spider
  • 14,881 posts
Posted 28 September 2023 - 06:04 PM
The Pot joints should be 1.250", I give the 0.001" running clearance, so 1.251" is what I set them at.
Often I'm finding the new Pot Joints though, are up to 0.0015" over size and / or out of round. If they are just over size, the bush can be machined to suit, however, I prefer to correct the Pot Joint, so if a replacement is later fitted, that is on-size, the bush isn't over-sized.
While getting a little off topic, KAD had a needle roller version of these covers.
#6 gaspen
gaspen
  • 949 posts
Posted 29 September 2023 - 05:28 PM
Yes I know it, and it will be reamed
I did it on mine Mini also 3 years ago and surprisingly it does not leak  :proud:
This one goes into a Special after re-build.
https://photos.app.g...kXR2FLTCCnbCCK7
