How To Secure Fuel Filter At Rear Of Car
11 replies to this topic
#1 Nel1972
Nel1972
    Starting My Mini Up
  • 4 posts
Posted 14 October 2023 - 08:38 AM
We have a 1972 mini and just replaced the fuel tank and flexible line.
looking at supporting the fuel filter adequately bearing in mind the frost, Highland roads and potholes!
Any recommendations. Have seen cable ties. Reluctant to drill subframe.
Thanks!  (Very new to all this so learning as we go along.  Mum and teenager project!)
#2 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 14 October 2023 - 09:32 AM
I use a piece of 6mm rubber against the subframe, drill the subframe and use cable ties or P clips (with rubber protection) and screws. I use the disposable tyoe
Edited by cal844, 14 October 2023 - 09:39 AM.
#3 nicklouse
  • 18,650 posts
Posted 14 October 2023 - 09:36 AM
Depends on the filter. Some have dedicated brackets. Some only need the support of the hoses.
what you using?
#4 Midas Mk1
Midas Mk1
  • 5,783 posts
  • Local Club: S.U.N.M.C
Posted 14 October 2023 - 09:38 AM
I use an old boot seal on the edge of subby, foam pipe insulation around the glass filter mounted where the injection factory filters normally are. Cable tied in place.
#5 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
#6 Nel1972
Nel1972
    Starting My Mini Up
  • 4 posts
Posted 14 October 2023 - 01:08 PM
Thanks for your replies   :-)
we are using a universal plastic in line filter.
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,364 posts
  • Local Club: Amoc
Posted 14 October 2023 - 03:37 PM
Enough fuel for thought there....
#8 Bobbins
Bobbins
  • 1,500 posts
Posted 15 October 2023 - 06:17 AM
Just checking … are you replacing an existing filter in the same location or installing something new? If it’s something new, make sure it’s in the fuel line after the fuel pump, not between the tank and pump.
#9 mbolt998
mbolt998
  • 390 posts
Posted 21 October 2023 - 10:23 AM
Why does it have to be after the pump? Mine is but it just seemed to be the easiest place to put it. If OP is talking about attaching things to the subframe it's presumably going to be before the pump.
Edited by mbolt998, 21 October 2023 - 10:23 AM.
#10 nicklouse
  • 18,650 posts
Posted 21 October 2023 - 10:38 AM
My pump has a filter on the inlet. Best place for it.
#11 andyapanel
andyapanel
  • 624 posts
Posted 22 October 2023 - 07:12 AM
You want the filter as close to the carb as possible to catch any crud that may come off the fuel line.
#12 Homersimpson
Homersimpson
  • 831 posts
Posted 22 October 2023 - 08:26 AM
Depending on the type of pump putting it between the tank and pump can cause issues, the original SU pumps can have issues with filters in the inlet and in extreme examples (as I once had) they can get stuck in the 'on' position and burn out the coil inside the pump.  This explains it it more detail:
https://www.dbraun99...s_and_Myths.pdf
This was mine next to a good one after I burnt it out!
Edited by Homersimpson, 22 October 2023 - 08:28 AM.
