Steering Rack Boots Broken
10 replies to this topic
#1 Anchoright
Anchoright
  • 127 posts
Posted 18 October 2023 - 12:46 AM
hey my steering rack boots are shredded and have been that way for a while, maybe a couple months. I know when a CV Joint’s boot is cracked it’s better to replace the whole CV Joint. I’m wondering if it’s necessary to replace the whole steering rack or is replacing the boots enough? I haven’t noticed anything wrong with the steering.
#2 Steam
Steam
  • 761 posts
  • Local Club: Victorian Mini Club
Posted 18 October 2023 - 05:47 AM
You can asses the condition after you remove them, they should be fine though.
Edited by Steam, 18 October 2023 - 05:50 AM.
#3 stuart bowes
stuart bowes
  • 2,117 posts
Posted 18 October 2023 - 07:30 AM
I'd be more interested in checking the inner tie rod ball joint. I.e disconnect the steering end and drop the arm. Does it fall immediately and then can you just wobble it about easily if so it's shot. And as far as I can tell unless someone provides a link, that part is very hard to find and replacement racks are cheap enough (aside from the work required to get it out and back in of course)
If the arms are still stiff and take effort to move / hold themselves in position, stick new boots on and carry on
and obviously because you've had to take the track rod ends off, asses them for possible replacement
Edited by stuart bowes, 18 October 2023 - 08:15 AM.
#4 PoolGuy
PoolGuy
  • 848 posts
Posted 18 October 2023 - 08:22 AM
Are Nitrol boots available for the Mini? They’re well worth the slightly higher cost as they last.
#5 mab01uk
mab01uk
  • 12,419 posts
Posted 18 October 2023 - 10:37 PM
Somerford sell Japanese Valtain Mini parts including:-
VALTAIN HIGH QUALITY STEERING RACK GAITERS
https://www.somerfor...ers-5-long-pair
but currently out of stock.
(Type 'valtain' in the search box)
https://www.somerfor...eywords=valtain
Edited by mab01uk, 18 October 2023 - 10:39 PM.
#6 ac427
ac427
  • 678 posts
Posted 18 October 2023 - 11:45 PM
https://classicminis...ing-rack-boots/
I wonder if these are the same?
#7 68+86auto
68+86auto
  • 911 posts
  • Local Club: Queensland Mini Car Club
Posted 20 October 2023 - 08:41 AM
They will be (well most likely).
Valtain is the brand of the JMSA (Japan mini specialist association) and is where most of the classicminisjapan.com parts come from.
#8 ac427
ac427
  • 678 posts
Posted 21 October 2023 - 12:44 PM
Thanks, Are there other JMSA members that might sell Mini parts, particularly the ball joints that don't require shimming?
#9 Cooperman
  • 23,286 posts
Posted 21 October 2023 - 08:10 PM
I have found that the steering rack gaiters currently available are made from very hard rubber and fitting them is not easy with the rack in-situ. I don't know whether the ones listed above are any better. Last time I gave up and fitted a good one from an old rack which I had.
#10 Anchoright
Anchoright
  • 127 posts
Posted 28 October 2023 - 01:55 PM
Thanks everyone for the help! You guys are great!
#11 68+86auto
68+86auto
  • 911 posts
Posted 29 October 2023 - 11:10 PM
If you go on the JMSA website there is a list of suppliers however they are all in Japan so you need to find one which wants to deal with foreign orders.
