998Cc Tuning
4 replies to this topic
#1 germini30
germini30
  • 722 posts
Posted 18 October 2023 - 08:18 PM
I have a 1989 998cc mini. Basically I want a bit more torque/power. I've fitted a stage one kit from mini spares already.
I have a 12G940B head in the garage, which is a mini 1275cc SPI head, so unleaded.
I was thinking of using this head and swapping the standard Cam for a mini spares evo cam. I can sink the valves in the head to safe pocketing the block, if that's a better option.
Has anyone got any advice on which way forward would be the best?
Thank you.
#2 Icey
Icey
  • 1,574 posts
Posted 18 October 2023 - 09:33 PM
Turbo, itโ€™s the only way ๐Ÿ˜‰
#3 andyapanel
andyapanel
  • 642 posts
Posted 19 October 2023 - 06:57 AM
A lightened flywheel makes a nice improvement to acceleration.
#4 Steam
Steam
  • 933 posts
  • Local Club: Victorian Mini Club
Posted 19 October 2023 - 08:27 AM
A 1275 head is not a direct replacement on a 998 engine.
A 1275 complete engine however, is, and will give you the performance you desire.
#5 coopertaz
coopertaz
  • 907 posts
  • Local Club: a-series-magpies
Posted 19 October 2023 - 10:03 AM
when i fitted a standard 1275 head to my 998 pocketed the block for valve clearance not the head and used a 1275 head gasket worked fine but you lose some low end grunt. would stick to cam swap and lightened flywheel.don't know what diff you're running but a swap to 3.44, including speedo drives, will improve things
