Hello;
I'm in the States or else I would book a session with AC Dodd to rectify the above problem.
Ignition is a Pertronix II module on a rebuilt 25D distributor with their recommended 0.6 ohm coil. Carburetion is 2 X HS4 SU's using MME needles and red springs, 20w-50 synthetic oil in the dashpots.
AFR gauge installed with oxygen sensor mounted on an LCB manifold just downstream of the exhaust collector with an RC-40 2 box system.
At idle I'm reading 12.5-13 AFR and climbs to 14.5-15 AFR on acceleration. Car pulls like a train. On deceleration and at low rpm or when coming to a stop the AFR goes to 16-17 almost off scale and the engine wants to stall.
I'm thinking ignition problem and may have to go back to contact breaker points and that may be the way to tell if any change happens with the way the car is running.
The lean condition on deceleration has me puzzled all I can reckon is that as the car decelerates it causes higher vacuum and the dashpots are being lifted too quickly causing it to go lean. Maybe go to a heavier yellow spring?
