Use Of Pinion Support
14 replies to this topic
#1 Java_Green
Java_Green
  • 176 posts
Posted 07 November 2023 - 01:21 PM
Anyone who has anything to say about the need for pinion support when it comes to a high torque engine?
My own thoughts is just that choice of a tall FD will at least reduce the bending force on the main shaft.
#2 nicklouse
  • 18,696 posts
Posted 07 November 2023 - 01:38 PM
Be aware there are a few versions.
some don’t have a speedo out put.
some don’t allow a rear mount engine “steady” to be used.
not needed in most applications. which you don’t say.
#3 Gaz66
Gaz66
  • 961 posts
Posted 07 November 2023 - 04:25 PM
I plan on fitting one when I build my box.
After seeing what a collapsed centre web bearing does to the internals it's not worth not having in my opinion especially if your going to be pushing it to the limit.
If the centre web bearing collapses or even just develops excessive play you can say goodbye to every gear in the box including the C/P.
Not sure who produces the best one though, I'm still gathering data.
#4 imack
imack
  • 2,199 posts
Posted 07 November 2023 - 05:38 PM
I fitted the KAD one after breaking teeth on my crown wheel and pinion.
I went for the KAD version as it allows the standard speedo drive to be used and looks standard from the outside other than the cast in KAD logo.
Mines fitted in a remote box and required modifications to one web of the pinion support to clear the gear change linkage.
It also required modification to the main shaft (carried out by KAD) to sleeve the speedo drive end of the shaft to fit the 17mm id of the support bearing inner race.
Edited by imack, 07 November 2023 - 05:44 PM.
#5 nicklouse
  • 18,696 posts
Posted 07 November 2023 - 05:56 PM
And I went for the MED one. I think they have done a second or a revised one.
#6 burchy35
burchy35
  • 115 posts
Posted 07 November 2023 - 06:40 PM
I fitted the Kad version to the swifty dog gears. It's a great box on the road and track. It handles plenty of mighty torque from the turbo with no issues to date 🤞
#7 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 07 November 2023 - 07:55 PM
I run the KAD one in mine. I'm running around 180lbft though.
#8 Shooter63
Shooter63
  • 1,073 posts
Posted 07 November 2023 - 11:20 PM
If you don't mind me asking, how does the crab claw and the selector rods fit in with the support in place?
Shooter
#9 nicklouse
  • 18,696 posts
Posted 07 November 2023 - 11:56 PM
Shooter
With ease.
#10 imack
imack
  • 2,199 posts
Posted 08 November 2023 - 05:04 AM
Shooter
I had to modify one of the webs on the KAD pinion support to clear the crab claw.
KAD now supply them ready modified for remote boxes.
Edited by imack, 08 November 2023 - 05:05 AM.
#11 Java_Green
Java_Green
  • 176 posts
Posted 08 November 2023 - 04:39 PM
Seems like a lot of people have gone for the KAD version. I guess it is advantageous to being able to use the speedo drive and a bearing inner diameter of 17 mm instead of 15 mm.
#12 nicklouse
  • 18,696 posts
Posted 08 November 2023 - 04:51 PM
That depends on your gearset.
#13 Java_Green
Java_Green
  • 176 posts
Posted 08 November 2023 - 04:59 PM
You are right. I have traced down the correct gears for my application. Not that I will bother to much about the speedo being fairly accurate but I need a working trip for the MOT. At the same time it is nice to have a working speedometer when the gauges are there.
#14 Java_Green
Java_Green
  • 176 posts
Posted 08 November 2023 - 05:22 PM
That is decent figure! At which engine speed? (which will give power figure...)
#15 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 08 November 2023 - 07:11 PM
I'd have to look at the graph, but roughly 5000rpm. It made around equal bhp so guess near 5250rpm.
Edited by Steve220, 08 November 2023 - 07:15 PM.
    Bing (2)
