Lightweight Flywheel Clutch Problems
20 replies to this topic
#1 goudoogje
goudoogje
  • 94 posts
Posted 08 November 2023 - 07:54 AM
Hi All,
I have purchased the MiniSpares Lightweight flywheel. (C-AEG421) Non vertro clutch with the old starter type.
To make it more complete, I purchased the new MiniSpares pressure plate and a new clutch plate to.
Last weekend I installed it all in my car, but now the clutch is not working at all..
The clutch was working fine with my old (stock) flywheel. I did checked the movement of the clutch arm, the adjustment of the arm, and all those are in good shape.
Does anyone have experience with this problem? Or with a Lightweight flywheel?
#2 KTS
KTS
  • 2,435 posts
Posted 08 November 2023 - 08:15 AM
what do you mean by not working at all - what are the symptoms ?
#3 johnR
johnR
  • 2,298 posts
Posted 08 November 2023 - 08:47 AM
I have that flywheel - the best mod I have made to my car, it really transformed my asthmatic old 998 - it's now on the 1293 I'm about to fit. Didn't have any problems at all fitting it - maybe start again and check your procedure?
#4 goudoogje
goudoogje
  • 94 posts
Posted 08 November 2023 - 09:19 AM
If you press the clutch pedel all gears are grinding, and you can not get them into gear because of that.
#5 Lplus
Lplus
  • 905 posts
Posted 08 November 2023 - 09:22 AM
Does the clutch pedal go to the floor with ease, or does it go hard immediately at the top pf the stroke and then not move further?
#6 mini13
mini13
  • 3,810 posts
Posted 08 November 2023 - 09:32 AM
this is a good resource,
https://www.minimani...FAQ__non_Verto_
often the issue is wear or mis adustment of the stops
#7 Spider
  • 14,892 posts
Have you adjusted the clutch since fitting it all up ?
You also need to check the assembly before fitting that it's getting the full clamping forces, often the backplate needs machining to get that right.
#8 KTS
KTS
  • 2,435 posts
Posted 08 November 2023 - 09:45 AM
gear selection is OK when the engine is not running ?
..in other words, problem feels like clutch is not fully disengaging ?
#9 goudoogje
goudoogje
  • 94 posts
Posted 08 November 2023 - 10:36 AM
yes, correct.
#10 goudoogje
goudoogje
  • 94 posts
Posted 08 November 2023 - 10:38 AM
Yes, the clutch arm is adjusted.
Backplace = pressure plate?
Does this mean the pressure plate from MiniSpares is not a direct fitment out of the box?
#11 bpirie1000
bpirie1000
  • Area Managers
  • 2,347 posts
  • Local Club: Amoc
Posted 08 November 2023 - 10:52 AM
Is the slave moving freely.?
#12 KTS
KTS
  • 2,435 posts
Posted 08 November 2023 - 12:53 PM
yes, correct.
when you depress the clutch pedal, does it feel like it's working as you'd expect (i.e. compressing the diaphragm spring) or is it lighter/heavier than before ?
Edited by KTS, 08 November 2023 - 12:54 PM.
#13 Spider
  • 14,892 posts
Posted 08 November 2023 - 06:23 PM
I found this thread on that covers how to check the Clamping Pressure and how it's adjusted;-
https://www.theminif...e-verto-clutch/
In particular, post #6.
Most of the after market backplates are supplied with slightly longer horns that usually what's needed, that way, there's material there that can be removed to adjust and set up what you have as not all clutch plates are made equal.
#14 whistler
whistler
  • 1,796 posts
Posted 09 November 2023 - 12:45 PM
Have you fitted the big 'washer', the one held in place by the wire clip, the wrong way round?
#15 Cheeser
Cheeser
  • 40 posts
Posted 09 November 2023 - 02:36 PM
Are you sure that the friction plate slides freely on the splines of the primary gear? If it is not free to move easily it can give similar symptoms.
