Well I was considering a seal unit LED conversion but don't want reporting to the police for blinding other drivers so will limit myself to just repalcement LED bulbs .
But the question is.....
I have the W&P type front grill so 4 headlamp units. I am going to have to rewire the inner 2 units anyway as looks like they were done many years since by Stevie Wonder when drunk. I can also change the type of headlamp or bulb I replace with.
The current set up is outside pair for dipped beam and inside pair for main beam. Now do I leave them as currently wired or start to play and use the all 4 for dipped beam lights or even have all 4 with both dipped beam and main beam lights.
Suspect I could give some 4x4s some lumen competition if I convert them all to main beam lights. The car is 1980 so technically no MOT requirement .
What have others done and any pro or cons? Probably won't get used much at night anyway but will certainly illuminate the garage .
Cheers.
