Mini Classic Running Problems
10 replies to this topic
#1 wurzel1974
wurzel1974
    Just On Tickover
  • 6 posts
  • Local Club: Somerset misfits petrol heads
Posted 20 November 2023 - 02:03 PM
Hello I’m at a loss to work out why my classic is running so badly, I’ve brought a new battery, alternator, ballast coil, and spark plugs and leads, and new electronic ignition,
What’s happened is when I’m driving along and put the lights on and the heater I lose power and the Mini becomes sluggish going up the slightest hill, if I turn them off the mini runs perfectly,
Also the number 2 and 3 spark plugs are black with soot, but numbers 1 and 4 are perfect, I’ve done a compression test today and got pretty much 175 all the way along,
Please can someone help please? I’m pulling my hair out, lol
Could someone please tell me the correct battery and alternator I should have brought?
The mini is a mini Mayfair 1983 Y reg thankyou very much everyone
#2 PACINO
PACINO
  • 821 posts
Posted 20 November 2023 - 04:47 PM
Hello! First of all, you should show up at the right place.
That said, it sounds like you have two problems. An electrical problem and poorly regulated carburetor, as two spark plugs remain black.
The first thing I'd ask is if the alternator is connected correctly.
Second, what idle speed do you have stopped? If the idle speed is below 900 rpm, the alternator may not be charging correctly.
Do you know if that coil with ballast is the correct one for your engine?
Greetings
#3 sonscar
sonscar
  • 3,254 posts
Posted 20 November 2023 - 05:07 PM
There are special considerations when fitting electronic ignition with ballast coils,Google it.You may have poor earth or battery connections at the boot or engine wiring.Steve..
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,565 posts
  • Local Club: Amoc
Posted 20 November 2023 - 05:12 PM
My thoughts are with this.. bad earth point... try cleaning up or replacing the earth strap. Or try a jump lead on the battery -'ve and one on the body somewhere first... see what happens.
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 20 November 2023 - 10:21 PM
I use an 063 size battery but you need to use extreme caution as the battery terminals are on the side that the battery clamp sits.
I suspect you have a charging fault and also need the timing, advance curve and carburettor optimised
#6 68+86auto
68+86auto
  • 1,479 posts
Posted 21 November 2023 - 12:39 AM
It sounds like there is a poor connection somewhere. Do not buy any more parts until the problem is diagnosed using test equipment.
What you can do is with it not running turn on the headlights and heater and see where the voltage is dropping (if it is the problem). Start at the solenoid and work your way along. check both the positive and negative.
Test, don't guess.
Edited by 68+86auto, 21 November 2023 - 12:40 AM.
#7 timmy850
timmy850
  • 3,606 posts
  • Local Club: MITG
Posted 21 November 2023 - 08:52 PM
Which electronic ignition did you buy?
Where have you got the power source for the electronic ignition?
As mentioned above, it’s critical that the ignition module gets 12v and not the reduced voltage from the ballast wire
Did you gap the spark plugs to the correct gap? Are the spark plug leads on in the right order?
#8 68+86auto
68+86auto
  • 1,479 posts
Posted 22 November 2023 - 12:57 AM
I missed the part about the electronic ignition, that means the coil could be incompatible too.
#9 sonscar
sonscar
  • 3,254 posts
Posted 22 November 2023 - 07:40 AM
Did you fit the new parts because it was sick?or has it become sick after fitting the new parts?Steve..
#10 wurzel1974
wurzel1974
    Just On Tickover
  • 6 posts
Posted 07 December 2023 - 12:20 AM
Hello thankyou for all the help, after checking all connections I think I have found the problem, the main battery cable from the battery in the back the ring connector has snapped, I also renew the earth cable on the engine and it seems to be ok now, just the two middle spark plugs to sort now, they still black,
#11 bpirie1000
bpirie1000
  • Area Managers
  • 2,565 posts
  • Local Club: Amoc
Posted 11 February 2024 - 10:40 AM
Have you considered a colour tune.
E.bay gunsons colour tune and you will be able to tune your own car better understanding of what is going on in the combistion chamber.
