Auxillary Fuse Box
5 replies to this topic
#1 Davidmt
Davidmt
  • 219 posts
Posted 26 November 2023 - 04:51 PM
I am going to add some auxillary items such as electric windows/USB etc.
I prefer to run everything I do from a separate fuse box so it's easier to separate/remove/change etc.
Will probaby mount it in the engine bay next to the original (I have bought the same 4 fuse box).
So the question is where to take the permanent and switched live feeds without causing any potential issues with any of the other electric aspects of the car - I was thinking of taking from the solenoid as I am replacing that next week anyway so can sort the wiring at the same time.
Any issues or better suggestions.  Needs to be at the front of the car otherwise I would have taken the permanent feed directly from the battery.
#2 KTS
KTS
  • 2,465 posts
Posted 26 November 2023 - 05:20 PM
take both feeds from the main battery terminal on the solenoid
create a switched live feed by running one of the feeds through a relay triggered off an existing switched live circuit
#3 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 26 November 2023 - 05:22 PM
For the permanent feed, starter solenoid is indeed your best bet.
For the switched, i would take it from the coil if you have it. use it and a relay to switch the permanent feed on/off and the output of the relay goes to the auxiliary fuse box
#4 Davidmt
Davidmt
  • 219 posts
Posted 26 November 2023 - 06:19 PM
Thanks guys - hadn't thought about using a relay to create the switched feed from the permanent feed but great idea and one I will use tomorrow!
Will also take the same approach for a lights on feed too :-).
Edited by Davidmt, 26 November 2023 - 06:21 PM.
#5 Davidmt
Davidmt
  • 219 posts
Posted 28 November 2023 - 05:44 PM
Managed to spend some time in the garage today so fitted a push button solenoid and also fitted a couple of relays with the extra fuse box at the same time.  I had forgotten how small and low the engine bay was (my back now aches!) but all sorted and now have a fused permanent feed, an ignition (coil) switched feed and a lights on switched feed so plenty to add a few auxillary toys!
Pleased with how it work and actually looks - thanks for the advice above :-).
Attached File  20231128_170642.jpg   61.02K   5 downloads
#6 KTS
KTS
  • 2,465 posts
Posted 28 November 2023 - 06:37 PM
nice job
one thing to note is that taking the switched live relay trigger from the coil +ve will mean anything on that switched live circuit may compete with the ignition circuit for power during engine crank (..the alternate switched live circuit doesn't get power during engine cranking)
