Cut Away Under Grille - Is This Normally Visible?
5 replies to this topic
#1 s2ulk
s2ulk
  • 96 posts
Posted 26 November 2023 - 08:57 PM
Hi all,
I was examining the grille on my 98 cooper today to work out whether I just need a new grille moustache (it’s got a bad dent) or whether I also need a new grille. And this cut away with a raised lip caught my eye - see green arrow on photo - it is quite prominent (more than the photo suggests). So it had me wondering whether it is common for this to be visible or a sign that my grille is also pushed in? Any feedback would be much appreciated before I order the replacement parts. Thank you.
Edited by s2ulk, 26 November 2023 - 09:11 PM.
#2 nicklouse
  • 18,598 posts
Posted 26 November 2023 - 09:15 PM
Not standard, not original.
#3 s2ulk
s2ulk
  • 96 posts
Posted 26 November 2023 - 09:53 PM
Well I just had a look at replacement heritage panels and this replacement front end MPI panel appears to have the same cut out so that suggests this is standard for MPIs:
https://www.bullmoti...60070/ASJ360070
#4 Quinlan minor
Quinlan minor
  • 1,177 posts
  • Local Club: LSMOC
Posted 26 November 2023 - 10:14 PM
It's a standard MPi panel, the 'cutout' is to accommodate the fan motor on the front facing radiator.
Edited by Quinlan minor, 26 November 2023 - 10:15 PM.
#5 mab01uk
mab01uk
  • 12,426 posts
Posted 26 November 2023 - 11:25 PM
It is visible because you have a '98 Cooper that has been retro fitted with the earlier Mk1 Cooper grille rather than the standard larger Mk2/3 onwards Mini grille.
#6 s2ulk
s2ulk
  • 96 posts
Posted 27 November 2023 - 11:10 AM
Thank you - that clears that up then. Think I will install a couple spot lamps to distract from it.
