Mini Van Sill 1 Inch Hole?
5 replies to this topic
#1 Ponyandtat
Ponyandtat
  • 12 posts
Posted 02 December 2023 - 05:11 PM
We are getting close to the point of fitting new outer sills to the new floor in a ‘80 van. The Sills have a 1inch hole which is just after the B post from memory.
Does anyone know the purpose of the hole?
Tony
Attached File  IMG_0016.png   138.65K   9 downloads
#2 mab01uk
mab01uk
  • 12,424 posts
Posted 02 December 2023 - 08:33 PM
This hole would be for the original jack to be inserted into the jacking point inside the sill which was reinforced behind but often rusted away.....so usually much safer to use a scissor jack or trolley jack under the front or rear subframe.
Edited by mab01uk, 02 December 2023 - 08:35 PM.
#3 KTS
KTS
  • 2,430 posts
Posted 02 December 2023 - 09:14 PM
..on a pickup it's where the load bed drain tubes come out
#4 Ponyandtat
Ponyandtat
  • 12 posts
Posted 02 December 2023 - 10:18 PM
Thanks for the reply, is it generally left as is , blanked off or covered with a grommet. The van had over sills when I bought it so no indication.
Thanks for the trolley / scissor jack tip but I was aware of that thanks.
#5 nicklouse
  • 18,596 posts
Posted 03 December 2023 - 01:02 AM
Yep often forgotten about the pickup and van sills are different.
#6 68+86auto
68+86auto
  • 917 posts
  • Local Club: Queensland Mini Car Club
Posted 03 December 2023 - 10:39 AM
it is NOT for the jack on a van. If it was for a jack it also wouldn't be a round hole.
Vans always had a jack to be used on the subframes as there is no set balance point as it could have a full load in the back.
