Do we have a thread (or has anyone started or intended to start one) related to what needs changing to be compatible with modern high ethanol content fuel?
It's unlikely the problem will go away, potentially it will get worse with many drivers swapping to electric and there likely becoming less demand for E5, therefore doing nothing isn't really an option. Also, using an additive can surely achieve only so much, the ethanol is still there so it might only buy some extra time?
I'm currently doing full rebuilds on two Minis, a 1986 and a 1998 so have the opportunity to fit replacement R14 fuel pipe etc while I have so much access, but what else needs changing? Ideally could we create a list of all the necessary items to be changed for various model years with the specification needed for each component, pipe length etc?
Even if the whole fuel system isn't updated, it would give a guide as to which components need a more regular inspection to check for issues.
Any thoughts?
Stu.
