Distributor Advance Mechanism
5 replies to this topic
#1 croc7
croc7
  • 818 posts
Posted 09 December 2023 - 07:41 AM
Is there any reason why I shouldn’t use WD-40 to lube the Advance mechanism on a distributor? just a little squirt through the hole in the plate should do it.
Edited by croc7, 09 December 2023 - 07:41 AM.
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,384 posts
  • Local Club: Amoc
Posted 09 December 2023 - 07:57 AM
Would really depend on why you want/need to squirt wd-40 in there?
If you have water in there and require that dispensed then yes.
Wd-40 = water dispersant........
The thin oil would also effect the grease that would be on the distributor shaft which is there stopping it from seizing.
Short term no real issue but will not replace genuine maintenance.
#3 Spider
  • 15,176 posts
Posted 09 December 2023 - 08:39 AM
It won't hurt, but as a lubricant, it won't last too long.
The usual way to lubricate the mechanical advance is to remove the rotor button and put a few drops of oil down the shaft. It's hollow and so does go all the way down to the mechanism - unless it's clogged up with old dried oil.
#4 sonscar
sonscar
  • 3,053 posts
Posted 09 December 2023 - 09:36 AM
There used to be a felt pad under the rotor for oiling in my youth,Steve..
#5 nicklouse
  • 18,711 posts
Posted 09 December 2023 - 08:35 PM
There are a few areas that need looking at. The bob weights pivots and the main pivot. The main pivot is under the rotor cap.
you really need to strip the dizzy to get the bob weights cleaned and lubed. Spraying WD40 won’t do much other than drip into the oil.
#6 mad4classics
mad4classics
  • 200 posts
Posted 10 December 2023 - 09:19 AM
Yes, replacement pads still available, just contact The Distributor Doctor https://www.distributordoctor.com/
