Problems With Initial Startup Twin Hsu2
7 replies to this topic
#1 minied69
minied69
    Starting My Mini Up
  • Just Joined
  • 4 posts
Posted 12 December 2023 - 01:31 PM
Hi,
I removed my working twin SU to test a Single HS6 setup. After 3 months, decided to go back to twins. Fitted the twins back and it refused to start. Did everything I know and it wouldnt start. As it was on the bench for 3 mths, thought could be a clog issue so cleaned and serviced the carbs. Note carbs has been rebuilt already with a full service kit a year ago. After cleaning, tried again and no luck. Troubleshooting done :
1) Checked fuel - Blew from Float bowl fuel inlet and saw fuel does come out the jet in the Main Chamber.
2) Lowered Jet by 9 flats and 12 flats as practice, removed dash pot and confirmed visually they are lowered
3) sprayed some fuel into chamber via filter side , car start a bit then dies when fuel finishes in chamber
4) Sparks from plugs are working, check one by one
5) Full Choke and no choke
6) Fethered throttle and closed
Suspect there is a vacuum leak causing hole in straw effect.. visually none visible.. what can I do to check and where?
Any help is much appreciated.
by the way if I fit back my HS6, car runs fine again so nothing to do with ignition.
#2 Spider
  • 15,201 posts
Posted 12 December 2023 - 04:06 PM
If there was any fuel left in them when on th bench, that would have dried out and possibly left a vanish or gum in the jets.
If you lift the lids on the float bowls (check them both), is there fuel in them ?
If you remove the bell chambers and look in to the Jets, can you see fuel in there ? It'll be about 5 - 10 mm down from the bridge.
#3 minied69
minied69
    Starting My Mini Up
  • Just Joined
  • 4 posts
Posted 12 December 2023 - 04:30 PM
Yes fuel.in float bowl. No fuel in chamber when remove dashpots. If I blow the float bowl fuel intake, fuel.comes out the jets so no clogs for sure.
#4 sonscar
sonscar
  • 3,062 posts
Posted 12 December 2023 - 06:16 PM
Gasket leak?have you fitted the air filter correctly?inlet manifold gasket leaking?basically everything you have touched.Steve..
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 12 December 2023 - 09:40 PM
look at AC Dodds videos in base carb set up pre to starting very usefull
#6 Steam
Steam
  • 843 posts
  • Local Club: Victorian Mini Club
Posted 13 December 2023 - 05:05 AM
Dribble a small amount of fuel into air intake chamber and try to start.
#7 minied69
minied69
    Starting My Mini Up
  • Just Joined
  • 4 posts
Posted 13 December 2023 - 06:35 AM
Found then issue, vacuum leak..manifold cracked and broke at cyclinder head.. back to my HS6...until get another manifold.. will try to weld back and test..
#8 minied69
minied69
    Starting My Mini Up
  • Just Joined
  • 4 posts
Posted 13 December 2023 - 01:20 PM
Found then issue, vacuum leak..manifold cracked and broke at cyclinder head.. back to my HS6...until get another manifold.. will try to weld back and test.. thxs all for the help
