Disc Brakes.
4 replies to this topic
#1 wednesdayite
wednesdayite
  • 25 posts
Posted 16 December 2023 - 08:24 AM
Morning boys n girls. I've got a 76 clubman and I've dropped a 1275gt motor in it. how do I know what size disc brakes to put in?. over here everything has to be certified after the work is done. I much appreciate your input. thanks.
#2 nicklouse
  • 18,998 posts
Posted 16 December 2023 - 09:43 AM
You can fit either size. Really depends on your wheel size.
the GT came with both 7.5” and 8.4” discs.
#3 mab01uk
mab01uk
  • 12,925 posts
Posted 16 December 2023 - 12:50 PM
Disc brake kit for 10" wheel early 1275GT and Cooper S:-
https://www.minispar...MS.aspx|Back to
Mk3 Cooper S and 1275GT Servo Kit:-
http://www.minispare...ssic/SEN43.aspx
Or you could fit the later 8.4" discs fitted to all 12" wheel Minis (including the later 1275GT) and the servo/master cylinder for dual circuit brakes fitted from 1988/89 to 2000.
Edited by mab01uk, 16 December 2023 - 12:56 PM.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 16 December 2023 - 03:08 PM
If it helps, my 74 Clubman i converted from all round drums to Cooper S 7.5" discs, Cooper S master cylinder, no servo assistance (unless you have a medical issue you really don't need it in a car that small)
Now this was with the original 998cc engine which was a peppy little unit and the car would happily stop from legal or not quite legal speed limits here. And it would pull up sharpliy.
I will have a cheeky little 1293 Seven port motor going in once its been on the engine dyno and i will run the same brakes with upgraded pads. All of this is on 10" Cooper S steel wheels. No servo.
#5 Ethel
  • 26,580 posts
Posted 16 December 2023 - 03:30 PM
If it needs to meet original standards they changed around '76
Pervious - 10 inch wheels, 7.5 discs, single circuit plumbing (with servo)
Post - 12 inch wheels, 8.4 discs, dual circuit brakes
Both used spacered rear drums.
