Coolant Pump Bearing
6 replies to this topic
#1 gaspen
gaspen
  • 1,169 posts
Posted 18 December 2023 - 04:56 PM
Hello
This is me again with the funny questions :D
So I just dismantled the coolant pump and - if possible - I'll try to save it.
Do you know if a bearing unit is available anywhere as a spare part ?
I guess 88G446 is the pump seal but I have no hit for the bearing
Attached File  20231218_111715.jpg   96.28K   5 downloads
#2 Spider
  • 15,684 posts
Posted 18 December 2023 - 07:36 PM
I haven't seen them available as a spare part for probably 35 or 40 years.
Part No. 12A1802.
#3 gaspen
gaspen
  • 1,169 posts
Posted 18 December 2023 - 08:13 PM
Part No. 12A1802.
Thanks Moke
Some bearing manufacturers produce very similar bearings, this is the closest hit
https://www.mby-bear...-pd6468464.html
#4 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 19 December 2023 - 01:55 PM
Apart from the fun challenge, I would be surprised if this "rebuild" is financially worth it
#5 slidehammer
slidehammer
  • 1,202 posts
  • Local Club: LSMOC
Posted 19 December 2023 - 02:00 PM
unless you are determined to have a period correct restoration, I would dump it and get one of the newer aluminium ones with a larger impeller. To get the best flow possible
#6 gaspen
gaspen
  • 1,169 posts
Posted 19 December 2023 - 03:11 PM
Price of the bearing is about 9 GBP. I can get it in 2 days from a local store
Bearind ID is 330902
From financial reasons view I would never ever touch a Mini  :D
#7 Spider
  • 15,684 posts
Posted 19 December 2023 - 06:08 PM
Thanks for the link. I have to say, I hadn't considered looking for them and at least by re-bearinging on old pump, at least we know the quality of the bearing.
Just be sure the impellar and pump housing are in good order with little or no corrosion or pitting.
