Thanks for the information.
As the direction indicators work as per design eliminates the wiring loom going to the lamps, the lampholders, the stalk switch and the direction indicator flasher relay. As it is the permanent live fuse that blows points to the wiring associated and components in this circuit.
My understanding of the wiring is as follows
From the permanently live fuse the Purple/Orange wire feeds the hazard flasher unit, and from the flasher unit the Light Green/ Pink feeds the hazard warning switch and as the fuse only blows when this switch is operated I presume these wires will be OK.
I can only see two earth paths here, either the flasher unit shorts to earth when operating or the switch shorts to earth through the inbuilt operating lamp circuit.
To fault find I would first check the switch circuit, two methods, either by substitution with a known good switch or by unplugging the switch and linking the Light Green/Pink, the feed from the hazard flasher unit, to the Green/Red and Green/White, the external lampcircuits, on the wiring loom plug. Remove the fuse, fit the links, reinstate the fuse and if all is well the external lamps should flash as per design and suspect the switch to be at fault, if the fuse blows it points to the hazard flasher unit as being faulty.
If the fuse blows reinstate the hazard warning switch in the circuit and move to the hazard warning flasher unit. Again try by substituting with a known good unit or remove the flasher unit and link together the Purple/Orange and the Light Green/Pink on the loom plug. With a good fuse fitted turn on the hazard warning switch and the external lamps should light but not flash and hopefully the fuse will not blow. If this is the case suspect the hazard warning flasher unit.
If the fuse blows I will have to give this a bit more thought.
Hope this helps with your problem.
