Reusable Air Filter Element
9 replies to this topic
#1 Rufus The Red Mini
Rufus The Red Mini
    Formally known as Aaaaaaaa
  • 73 posts
Posted 20 December 2023 - 11:20 PM
Is there an alternative to the paper air filter element that is reusable other than the K&N version, ie cheaper.
#2 Avtovaz
Avtovaz
  • 1,306 posts
Posted 21 December 2023 - 12:25 AM
run with out one, zero cost!
watch the bore wear though.
#3 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 21 December 2023 - 07:42 AM
Put an old oil-bath 'filter' in  :gimme:
#4 andyapanel
andyapanel
  • 642 posts
Posted 21 December 2023 - 07:43 AM
You get what you pay for
I have run K and N for decades without a problem
Do some research on engine wear if you decide to run something else.
Don’t forget to drill the air box to improve airflow, too.
Keith Calver has covered these topics thoroughly.
#5 Earwax
Earwax
  • 577 posts
Posted 21 December 2023 - 07:44 AM
You were probably already aware of these different style set ups, but i will wade in just in case.
There are Ramflo style airfilters
You would have to buy the Cage to start with , so your cost equation is probably looking dearer for an up front cost. Read up on offset to best fit in with your firewall
The filter foams are able to be washed and reoiled ...... debate over whether and what oil is appropriate also exists
Different foam manufacturers also .. and guess what ,,,debate over best exists...... I have been happy with Lynx filters and foam filters   BUT
the foam ones do crumble after long heat exposure... and That would not be the best thing to ingest into your carbie ( if in doubt throw it out)
I think the relative cost of the paper air filters generally comes down to how well they are made - thickness of fins etc - if you are happy giving the mini premium oil , then i think it wise to not skimp on an airfilter
#6 stuart bowes
stuart bowes
  • 2,530 posts
Posted 21 December 2023 - 09:25 AM
am I missing something obvious or are we talking about the filters that are like £7-8 from minispares
https://www.minispar...|Back to search
better still find one on ebay and get free postage as long as you're happy about quality of parts
https://www.ebay.co....:Bk9SR-TPpLuRYw
how often do they even need replacing, what like 2-3 years depending on useage
at that rate youd have to change it about 6 or 7 times to get to the point where a reusable K+N one would have saved you money (20 years?)  so cost isn't really the issue I don't think, I would be more interested in whether or not there was a noticeable performance difference between the two (negligible I would imagine on a day to day road car but happy to stand corrected)
Edited by stuart bowes, 21 December 2023 - 09:29 AM.
#7 PoolGuy
PoolGuy
  • 975 posts
Posted 21 December 2023 - 12:50 PM
Strikes me that it'd be more expensive rather than 'zero cost'?
#8 slidehammer
slidehammer
  • 1,202 posts
  • Local Club: LSMOC
Posted 21 December 2023 - 01:37 PM
Personally I would either go for a branded re-usable filter like K&N or stick with the paper elements. Both designs filter particles well. The K&N when set up properly (maybe with a needle change) will give a slight power increase, but in my opinion it would be slight especially if it is an element in standard filter housing. Steer clear of any unbranded 'performance' air filters from Ebay.if they don't filter properly they only increase engine wear not power
#9 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 21 December 2023 - 08:11 PM
Penny pinching on an air filter? Really, don't get it at all.
k&n aren't expensive for an airbox.
For an an airbox, k&n.
For ultimate performance, itg and med stubstack (again, washable) I clean and oil mine on every oil change.
Edited by Midas Mk1, 21 December 2023 - 08:12 PM.
#10 Steam
Steam
  • 933 posts
  • Local Club: Victorian Mini Club
Posted 21 December 2023 - 11:46 PM
Just ignore the reuseable sales hype and fit a good quality paper filter. Best filtering so no engime damage.
