Lubricate Starter Motor
8 replies to this topic
#1 theoldmini
theoldmini
  • 133 posts
Posted 12 January 2024 - 09:27 AM
Is it possible to lubricate the shaft on the starter motor.  My bendix does not seem to run as smooth as it should.  Battery is fully charged and all leads connections are good.
#2 coopertaz
coopertaz
  • 811 posts
  • Local Club: a-series-magpies
Posted 12 January 2024 - 10:55 AM
used to put a small amount of very light spray oil on here and work bendix till smooth. is used duck oil spray not wd40
#3 theoldmini
theoldmini
  • 133 posts
Posted 12 January 2024 - 11:41 AM
Brilliant thank you.  Have put as small amount of light machine oil and now all smooth.  Thanks for the tip
#4 andyapanel
andyapanel
  • 627 posts
Posted 12 January 2024 - 12:16 PM
Be careful:oil can cause dirt to stick to the shaft and make the situation worse. Try degreasing it, instead.
#5 nicklouse
  • 18,724 posts
Posted 12 January 2024 - 12:19 PM
Graphite powder is the correct thing to use.
#6 theoldmini
theoldmini
  • 133 posts
Posted 12 January 2024 - 02:48 PM
Have ordered some grafite powder.  Will degrease with brake cleaner and then apply small amount.  I see can be used on door locks also so another little job. Appreciate all thoughts
#7 Designer
Designer
  • 630 posts
  • Local Club: LSMOC
Posted 12 January 2024 - 04:14 PM
Graphite powder is one of the most useful dry lubricants you can get. If need be you can use the crushed lead from a pencil, but do not rely on that for anything important as it is not necessarily pure graphite, but for the odd stubborn lock or squeaky hinge it is ok.
#8 theoldmini
theoldmini
  • 133 posts
Posted 13 January 2024 - 03:55 PM
Graphite powder applied only a small amount and all seems good.  Thank you
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,398 posts
  • Local Club: Amoc
Posted 14 January 2024 - 04:01 PM
I shall pencil that in on my garage shopping list...........
