Engine Lube
13 replies to this topic
#1 germini30
germini30
  • 699 posts
Posted 14 January 2024 - 07:35 PM
Rebuilding a 1275 and am going ro be fitting the pistons and crank etc soon.
Would you use a lube such as Lucas lube on the bearings etc upon assembly or not.
#2 Spider
  • 15,163 posts
Posted 14 January 2024 - 07:40 PM
If it's going to be built and then run soon after, I prefer using engine oil.
If it's being built and stored for a while before running, then a decent engine assembly lube - but keep that away from the rings and bores !
#3 germini30
germini30
  • 699 posts
Posted 14 January 2024 - 08:02 PM
OK brilliant, I'll stick to some oil if that's best. Engine won't be stood too long
#4 germini30
germini30
  • 699 posts
Posted 14 January 2024 - 08:46 PM
Just watching a mini guy putting an engine together on YouTube and he lubes up the bore walls.
#5 Spider
  • 15,163 posts
Posted 14 January 2024 - 09:57 PM
Yes, but I'm sure that's with oil, not engine build lube !
#6 germini30
germini30
  • 699 posts
Posted 14 January 2024 - 10:01 PM
No, he uses it on the mains and big ends then smears it in the bores before fitting the pistons. Atleast with engine oil it's a lot safer , especially with the gearbox in the sump
#7 weef
weef
  • 506 posts
Posted 14 January 2024 - 11:23 PM
MMMMMM..........   UTube and good source for misinformation.
For an assembley lube I have always used a mixture of clean engine oil and a high molibnium  grease, making it into a thin paste capable of being painted onto the required bearings, it adheres well to the surfaces.
Always remember to prime the oil pump before fitting, I use a  petrolium jelly on the pump lobes for this purpose.
#8 germini30
germini30
  • 699 posts
Posted 15 January 2024 - 08:58 AM
That's why I thought I'd ask on here, some stuff you see certainly makes you think
#9 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 15 January 2024 - 09:22 AM
hope he has garage door open starting that up
#10 germini30
germini30
  • 699 posts
Posted 15 January 2024 - 12:03 PM
Haha yes hope so.
#11 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 15 January 2024 - 01:30 PM
Only use engine oil on cylinder walls. Assembly lube isn't ideal. I've seen people dip the piston in a tub of oil prior to fitment too. This is also a dumb idea. Liberal amounts of oil between the rings will coke up quickly causing issues during the 50 mile run in.
#12 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 15 January 2024 - 01:31 PM
I do normally use a cam lube on the lobes and followers though. The rest I would do with engine oil and fill the oil pump as well. Especially as the engine is to fitted and used quickly
#13 bpirie1000
bpirie1000
  • Area Managers
  • 2,383 posts
  • Local Club: Amoc
Posted 15 January 2024 - 03:10 PM
Al always with mini things. Spent a fortune on new bearing, now line bore new pistons new this new that..
Saving on 10quid of some building lube protection here is a false economy.
Buy what you can for what you need..
#14 germini30
germini30
  • 699 posts
Posted 15 January 2024 - 08:34 PM
I'm ordering a tube of lucas pre lube from amazon.
Way I see it is why not put a smear on the crank bearings, big ends, small end as well as the cam.bearings and followers.
It's about £10 and could provide protection until the oil gets pumped around the engine.
If I remember correctly I once primed an oil pump by putting oil into the block, where the oil filter head screws into the block whilst turning the engine backwards.
