Hi,
My recently rebuilt engine in my Mini is a 1275 A+ Block pulled from a 1989 Metro.
I have fitted a Fletcher Alloy radiator which has a drain plug on the bottom. I want to completely drain and then flush the coolant.
I have asked about flushing before and had various methods offered, but I never managed to find out how to completely drain the coolant.
I have recently had a problem with water in my oil and have taken the head off, hopefully sorted the problem and have just re-assembled the head with a new gasket. Even though I have drained the coolant from the radiator, there is still coolant (water and water wetter), in the block.
I have read a post here about a drain plug on the rear of the block, sadly this A+ block does not have the mentioned plug. Had I know this I may have drilled and tapped one in (if that would have been possible) as it would no be really handy.
Here's my block, you can see the protrusion where the drain plug would have been:
Any other thoughts on draining the block with the engine in the car? Or is it (as I think) impossible.
